Two Way Radio Forum
Go Back   Two Way Radio Forum > Two Way Radios > Consumer (FRS / GMRS) Radios
Reply
Thread Tools Display Modes
  #1
Old 03-28-2018, 11:40 PM
Youssefaly97 Youssefaly97 is offline
Junior Member
Default Motorola talkabout T5720 repair
Hello, I'm an undergrad electronics and communications engineer.
I have a pair of Motorola Talkabout T5720 radios, one unit I think is fully functional. It transmits fine and I haven't tested how well it can receive. I can receive from it on a software defined radio receiver on my pc. The other unit doesn't receive or react when the first one is transmitting and when I press PTT, there is RF power output but there is no carrier. I can see that on the spectrum of the SDR receiver.
I think it might be a local oscillator problem, any pointer on how to start diagnosing that?
  #2
Old 03-29-2018, 04:57 AM
Chickenhawk Chickenhawk is offline
Senior Member
Default Re: Motorola talkabout T5720 repair
If you really are a communications technician, then you will NEED a good frequency counter and RF strength meter. A scanner will not tell you the strength or "privacy" tones of the transmitter. You will need a frequency counter.
If you then find the second Talkabout radio does not have tones enabled and still does not work, then you will learn quickly that lesson one of consumer FRS radios is that they are not designed to be repaired. If they don't work, they are thrown away. The cost of your time and the price of the parts will easily exceed to cost of a cheap two-way consumer-quality radio.
  #3
Old 03-29-2018, 01:44 PM
Junior Member
I have a software defined radio, I can see the whole spectrum from 25 MHz to 1.7 GHz, I can measure frequency down to 0.5 PPM and I can measure RF power relative to the background noise.
The second unit, the one not transmitting, when I press the PTT, it raises the noise floor seen by the receiver significantly. I can post a screenshot when I get to it. I can conclude that the rf power amplifier inside it is working but is amplifing noise. That may point that the local oscillator is not working but I'm not sure.
Reply
Bookmarks
Tags
frs, gmrs, motorola, repair
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
