Two Way Radio Forum
View Poll Results: Does this review help in your purchase decision
yes, very helpful 10 100.00%
No, not helpful 0 0%
Voters: 10. You may not vote on this poll
Reply
Thread Tools Display Modes
  #1
Old 05-29-2007, 11:05 AM
jwilkers jwilkers is offline
Moderator
Default Midland GXT850 Review
FCC ID: MMAGXT850
Power Output ERP:
1.6379 Watts (GMRS High)
0.278 Watts GMRS/Med
0.2035 Watts (FRS/Low)
Advertised power output 5 watts
This radio had a hefty look and feel. It is advertised as being waterproof.
I did not test this.These radio have both CTCSS and DCS coded squelch
to assist in interference protection.
Sound Quality: The radio had a nich hefty audio quality. Volume was
sufficient for all but the noisiest environments.
Ease of operation: I considered the menu layout to be confusing at first.
Setting CTCSS and DCS codes was a bit more complicated than I would
have liked to see. Nonetheless, after learning the functions with
the help of the manual, I was able to navigate easily. CTCSS and DCS tones/codes are listed in the manual.
Advanced Features: These radios have an advanced selective calling system. It allows each user to input an
ID tag and selectively call individual radios, or the entire group. Each radio is set with an
ID tag and a group number. This system is effective with large groups and wasn't tested
in a group mode. It worked great with the two units I had. At first, it was a bit complicated; but we got it down after
a little while. These radios offer Voice Operated Transmit (VOX) for hands-free operation. A silent "vibrate" function is also available.
Scan function: If you set a CTCSS/DCS code, and then scan, the scan function "remembers" these codes and when it scans that channel, it will scan the pre-set code too. This is useful if your group operates on different CTCSS/DCS coded channels. These radios will not display, or scan a CTCSS/DCS code if they are not pre-set. As such the radio isn't good for "finding" codes.
Ranges: (Test area was in a suburban environment. Your experiences may vary based on terrain and environment)
(Squelch enabled, Maximum effective range)
Car to car: .75 miles
Car to house: 1.18 miles
Person to person outdoors: 1.55 miles
Person to house: 1.18 miles
Battery Life: Charge life of supplied battery pack is effective for
normal use all day. Battery did not indicate loss of power during
test period. Supplied charger charges both the supplied pack, and your own
AA cells.
Final Comments: I enjoyed these radios. Admittedly, they were a bit more
complicated to use, but then they had a lot of features. They are durable and effective.
Scan function does not allow for locking out undesired channels or display CTCSS/DCS tones.
I consider this a drawback.
As with All GMRS capable radios, and FCC-Issued GMRS license is required for GMRS frequencies.
Last edited by jwilkers; 07-24-2007 at 11:21 AM. Reason: Added statement indicating license requirement.
  #2
Old 07-24-2007, 11:10 AM
Moderator
Default Re: Midland GXT850 Review
These radios were used on our Florida vacation. Our communications never exceeded about a half mile or so; but communications were crystal clear and perfect. While we never got them in the water, they certainly did well in the Florida humidity (no displays fogging up and such).
  #3
Old 09-16-2007, 06:49 AM
plateshooter plateshooter is offline
Junior Member
Just got back from a fishing trip in Canada. GTX 850s worked well except for one which occasionally "squealed" when receiving at first. It seemed to stop that after the first day. We did test the water proofing on one of the radios when it was dropped in the lake while docking a boat. The water proofing held, with no damage or operational problems with the radio. I looked under the battery cover, and headphone cap etc and could find no water anywhere.
Using channel 18 on High Mode, these radios got more than 3 times the range we could get with my Motorola FMRS radios. They worked well for vehicle to vehicle while traveling and from boat to boat on the lake.
I would recommend them from my experiences with them.
  #4
Old 09-18-2007, 02:31 AM
2waytalk 2waytalk is offline
Junior Member
Are these models above the Midland GXT800?
Good review.. I'm just comparing the midland line of 2 ways. Looking to get the GXT800 but all I can find are bad reviews and complaints on the distance.
  #5
Old 09-18-2007, 01:02 PM
Moderator
Same basic radio. Just different features. All the specs are the same.
What you get on bad reviews is that people expect the "25 mile range" or whatever these guys advertise. When they experience reality, they give a bad review.
These radios perform like any other consumer grade radio.
I recommend them.
  #6
Old 09-18-2007, 02:30 PM
Danny Danny is offline
Administrator
Like jwilkers says, most of the bad reviews are out there because the consumers expections were not properly set. When some sites only publish the manufacturers advertised range, it is easy to see why a customer would be disappointed in the product.
The fact is, these consumer grade radios are very useful for many applications, and simply the wrong tool for the job in others. We've found that it helps immensely to let customers know what to expect before the sale.
For a consumer grade product, the Midland GXT800 is a great choice. It offers tons of features, great voice clarity, and typically 1-2 miles of range.
Danny
__________________
BuyTwoWayRadios.com
  #7
Old 11-08-2007, 06:45 AM
Moriarty Moriarty is offline
Junior Member
Did anyone on this forum had the chance to test this radio in the mountains? I would be interested in the maximum range obtained in a line of sight scenario where Earth's curvature is still not a problem (valley to mountaintop) but also in the case of the two radios both being in a deep valley with no visibility, where UHF performs really bad...
  #8
Old 11-08-2007, 02:18 PM
Moderator
Quote:
Been done with FRS radios many years back. The record is somewhere around 125 miles.
PS>>> don't let the FRS/GMRS manufacturers see this... otherwise.. netx year's models could be advertised as 125 mile radios
  #9
Old 11-25-2007, 06:13 PM
Junior Member
I have a question about the included rechargeable battery packs: what is the rated capacity in mAh, and the rated voltage written on the pack (4.8V or 6V)? Thanks in advance!
  #10
Old 11-26-2007, 01:34 AM
Moderator
Packs are 6V 700 mAH.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
