| Click here to visit our ecommerce site - BuyTwoWayRadios.com |
| View Poll Results: Did this review help in your buying decision | |||
| Yes |
5 | 100.00% |
| No |
0 | 0% |
| Unsure, still researching |
0 | 0% |
| Voters: 5. You may not vote on this poll | |||
Thread Tools | Display Modes |
#1
Motorola T9500 Review
FCC ID: K7GT9500 Power Output: 1.03 Watts GMRS .11 Wats Low/FRS This radio has a nice attractive package that fits comfortably in the hand. Its design prevents it from sitting upright, such as standing on a table. This radio has both CTCSS and DCS coded squelch for interference protection. These radios don't separate DCS and CTCSS codes. Codes 1-38 are the standard CTCSS codes. Codes 39-121 are DCS codes. There is no chart giving the codes. You have to guess, so it could be a challenge setting these radios to work with other brands. Sound Quality. The radio had a nice smooth sounding audio. The compander feature assists in removing background hiss. Volume levels are not high enough to compensate for extreme background noise, as you may experience at places such as amusement parks. As these radios have a compander circuit, hearing radios of other brands may sound a little odd, as they don't have the same circuitry. For the most part, this isn't too objectionable. Ease of operation: The menu was easy to navigate and access to functions was simply laid out. Access to the advanced functions was easy, and rarely required consulting the manual. Advanced Functions: This series has the QT interference protection. This allows similar radios to communicate with one another, with added protection against other radios "opening the squelch". This is used in conjunction with CTCSS/DCS. (NOTE: This is not an encryption or scrambling system, and does not prevent others from hearing you) The scan function allows you to lock out channels you do not wish to scan. This is a VERY big plus. Also, when scanning, it will display the CTCSS/DCS tone of the active channel. Another positive. These radios also offer Voice Operated Transmit (VOX) for hands free operation. High and low power are selected by pressing either the upper or lower transmit button. FRS-only channels are low-power only. These radios offer NOAA weather reception with a weather alert function. Ranges: (Test area was in a suburban environment. Your experiences may vary based on terrain and environment) Advertised Range: up to 26 miles Tested Ranges: (Squelch enabled, Maximum effective range) Car to Car: .75 miles Car to house: 1 Mile Person to house: 1 mile Person to person outdoors: 1.3 miles Battery Life: The supplied pack indicates loss of power after 4 hours or so. It remains useable for 8 hours (which is my test standard, typical for most folks) I suggest extra batteries. I used AA rechargeables which definitely exceeded 8 hours full power. The supplied chargers ONLY charge the supplied pack and will not charge other batteries. Additional Comments: I found the belt clips to be cabable of easy damage. I didn't break them; but they don't seem very durable. Other than that, I can't complain. I found these radios of a very good quality, and will enjoy using them. Interference from household electronice is limited. The best I've seen on a consumer radio. I will handle any questions on this radio. Last edited by jwilkers; 06-09-2007 at 11:56 PM. Reason: Additional comments. |
#2
Good review. Now I know what to expect out of my T9500's. Regarding the CTCSS/DCS codes, I don't know if this is any help but, I found the following link that contains the CTCSS codes for the Motorola along with the differences in other radios. It also shows some DCS codes but, I couldn't make heads or tails out of it. Hope it helps.
http://www.n8lhg.com/gmrs2.htm Harry |
#3
It's an older list... not current for the current mosels... Thanks anyway.
#4
Have you the actual size, weight and antenna length of the T9500. Has it an external antenna jack/port.
Thanks, Louis |
#5
Quote:
Since these radios use FRS frequencies, there is no provision for an external antenna, as FRS regulations forbid the use of external antennas. Hope this helps. |
#6
I have used my T9500 in several instances.Boating they preformed quite well and distance along with reception are optimal. While using them in campsites they did work well although line of site was the factor.I have used them in a noisy environment and if you use a quality headset and boom mike they preform quite well.(The Motorola brand is reasonable and works great).I did however choose to purchase a marine radio for the boat which also uses the frs frequencies and a Rino 530 for my camping use.As for the T9500 radio's,still have them,still use them and they still work great today.
#7
What does the roger beep on this radio sound like?
#8
What ever it is it will MOST certainly be ANNOYING!
#9
#10
The roger beep on the motos isn't as annoying as most. It's more subdued. Of course, you can turn it off, so it can be a nonfactor.
| Bookmarks |
| Thread Tools | |
| Display Modes | |
