| Click here to visit our ecommerce site - BuyTwoWayRadios.com |
| View Poll Results: Has this review affected your buying decision? | |||
| Yes it has. |
2 | 66.67% |
| No, it has not. |
1 | 33.33% |
| Unsure, still researching. |
0 | 0% |
| Voters: 3. You may not vote on this poll | |||
Thread Tools | Display Modes |
#1
Motorola EM1000R Review
FCC ID: K7GEM1000 Power output: 1.92 W ERP GMRS 350 mW FRS This Radio requires a GMRS license on ALL channels *except* channels 8-14. There is no low power operation capacity on the shared FRS/GMRS channels. Features: 22 channel FRS/GMRS operation CTCSS and DCS coded squelch. Weather channels with alert function. QT interference protection Built in LED flashlight Emergency panic alert function. Channel scan USB charging capability. VOX function. Dual power. (Motorola Pack or AA cells) Single-pin speaker mike jack Motorola's 2008 models incorporate the newest technology and innovations to their consumer radios. It was a pleasure to put this model through its paces. I was not dissappointed. Features I single out for comments: Operation is easy and straightforward. I had no problem with navigation through the menus. Everything was logically ordered and made sense. The new flashlight function has a single, white LED. It is of sufficient brightness to illuminate small areas, looking for keys, etc. Nice feature. The USB charging function is nice, if you want to charge the battery pack off your computer. No USB cable was included, but I have one each from my digital camera and Video Camera. The charging stand and USB charger will only charge the Motorola battery packs. If you use AA cells, these functions are not avaialble. The Motorola packs are decent. For better life, you can use your own cells, a nice option. This doesn't make you depend on proprietary battery packs. The Emergency alert function will sound a panic alarm, then open the transmitter to pick up any sounds in the operator's area. The emergency button must be pressed for a couple seconds, so there is little chance of a false alarm. The scan function allows you to lock out channels during scan. A vital feature, in case of interference, either from annoying users or household electronic interference. The QT interference protection, a feature in most Motorola models of late vintage is nice if you will be in a crowded area. It will help weed out annoyances on the channels. Operational performance: Battery Life: Average. Over a 5 hour scan period, the radios lost one bar. They were operational past this time. Typically, a scan cycle is fairly power intensive. They should last during a typical day's use. Audio: Volume is sufficient for average use. In an noisy, crowded area, it may be best to use a speaker mike. Received audio is okay. I wouldn't put it at the top of the list, but it is understandable. Communications Ranges: House to car: .68 mile Car to Car: about .5 mile Person to person outdoors: 1.28 miles House to person outside: 1.11 miles Terrain is suburban, with houses, some commercial properties and a lot of trees. Your experiences may differ. I found these radios, as usual, a pleasure to review. I have a set of last year's models and they compare in many ways. Operation is identical in most respects. Oddly enough, with an increase in power output over the 2007 models, I saw no significant improvement. I believe, antenna design plays a factor in this. There were no visible changes in antenna design. Again, terrain plays a factor though. I recommend these radios. They work well, and will serve well. |
#2
jwilkers,
A sincere word of thanks for the effort you are putting into your reviews which is very, very usefull !!! You are really covering all issues of interest and make it very easy for anyone to make up their mind on what radio to 'invest' in, based on their individual requirements . Great Job Well Done !!!Just a few questions: 1) Is the comms range test for each radio done in exactly the same location/place? 2) if ordinary (e.g. duracell) AA batteries (with a inherent higher volage than rechargeables) are used, would there be any change in the comms range? Thanks again, and keep up the excelent work!! Best regards, Louis |
#3
Quote:
For power, I use the supplied battery packs. What comes in the package, I use. I do this to keep the tests as close to what the manufacturer has designed into the radios. My tests and evaluations provide a "guide". They don't provide a "Gospel Truth". I've seen many a person come out with results quite different from mine at times. With UHF, it is so terribly difficult to get exact results under all conditions. |
#4
Hello there,
Thanks for the useful review. I bought this model at the end of August and I am having problems with it. Both handsets were working before but last night one of the handsets could not transmit, but can only receive. Can anyone help me with suggestions on how to get it to work? Both have the same settings. Thank you. |
#5
Quote:
Try different channels without the "privacy codes" enabled.
__________________
Supporting eXRS. 10 Billion channels, no interference. TriSquare is a winner! |
#6
OK thanks. Will do as suggested now and report back
#7
I have changed the channel and turned off the privacy code as well, but it has not worked. The battery is fully charged.
#8
sorry..... looks like a bad unit
__________________
#9
Just to add that there is no transmission sound at all from the handset - apart from the usual sound when I press and release PTT.
#10
Hi....
this site is really gud... thanx..... |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
