Two Way Radio Forum
Reply
Thread Tools Display Modes
  #1
Old 11-13-2017, 11:28 AM
dollargriffin93 dollargriffin93 is offline
Junior Member
Default Motorola XU2600 Antennas & Long Range
So I have a fleet of 20 Motorola XU2600 radios. 10 of them are placed in vehicles along with a Motorola PTT handheld mic. The other 10 are just carried around at the job site. The original antennas are dry-rotting, and they are all breaking and falling off, exposing the copper inside. My question is can I replace the original antennas with new ones? And for the ones in the trucks, is there a way to use a rooftop antenna with them? Also, what kind of range will a rooftop antenna provide?
  #2
Old 11-13-2017, 12:22 PM
Rick S Rick S is offline
Administrator
Default Re: Motorola XU2600 Antennas & Long Range
Quote:
Hi, the antenna on the XU2600 is not removable, so repairing the antenna is really not feasible. Although we did carry them, the XTN Series was discontinued over seven years ago, so even if they could be repaired, the likelihood of obtaining OEM replacement parts from Motorola is extremely low.
These radios were not designed to use mobile or other external antennas, so there is no option to properly connect one.
A properly installed external antenna may increase range significantly. Of course, a lot also depends on the structures and terrain around it, however connecting a handheld radio to an antenna on the rooftop of a vehicle much more efficient than using it with the attached antenna from inside the cab, simply because it will be situated at a higher point and the signal won't be slowed by the glass and steel surrounding the interior.
  #3
Old 11-14-2017, 11:29 AM
Junior Member
Thank you very much!
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
