Go Back   Two Way Radio Forum > Two Way Radios > Digital Radios
  #11
Old 04-22-2018, 01:15 AM
AF5SX AF5SX is offline
Location: On the road. I am a truck driver by profession.
Angry Re: TYT MD-9600 Programming
I just bought a second MD 9600, because my first one seems to have gone brain dead. (I was distracted while building a code plug, and hit "write to radio". Before it finished, I hit "cancel." From there, it's brain dead. Will not accept a code plug. CPS will not identify radio. Nothing. that's the first radio)
New radio: Firmware version: D005.005. CP Version: V01.12.
It will not accept a code plug.
When I open the CPS, open a code plug, hit "Write" "OK" it shows that it is writing, then shows "Write successful"
The code plug contains one Analog frequency: 146.520
The rest of it is set up for use with my Nano Node.
BUT, all that shows on the screen of the radio is: Shows indication of Analog, "Sample" and "Unprogrammed".
What theheck is up with these bloody radios?????????
  #12
Old 04-22-2018, 06:29 PM
Tim N3LYT Tim N3LYT is offline
Default Re: TYT MD-9600 Programming
If there is nothing in the "B" band it will display unprogrammed. These are not the easiest thing to program. Put your zones in A simplex etc, analog in B. Well to be frank it could be either you could switch the A and B but there must be something in the other side This is a dual band in the simplest sense but it is wanky. I have yet to get the "P" buttons to work the way they should.
  #13
Old 07-07-2018, 03:31 PM
Firechief120 Firechief120 is offline
Having similar problems as others. Just installed 5.03 firmware. Now my Channel B shows as unprogrammed. Anyone know the fix? My channel B is analog frequencies and was working fine before. Thanks. W8BRY.
  #14
Old 07-08-2018, 01:05 PM
Found the solution thanks to another ham. The current CPS 6.03 released on 03/22/2018 will fix my issue listed above. Hope this may help others. 73's. W8BRY
  #15
Old 07-25-2018, 09:33 PM
WA6YVX WA6YVX is offline
I have an MD9600 with firmware 6.003 and CPS 1.23. I cannot load more than
10,000 contacts. I thought this would load up to 100,000 contacts. Anyone else have the same problem?
