Two Way Radio Forum
Go Back   Two Way Radio Forum > Two Way Radios > Amateur Radio
Reply
Thread Tools Display Modes
  #1
Old 11-22-2014, 05:27 PM
bzirk bzirk is offline
Junior Member
Exclamation Troubles Programming Baofeng UV-5R
I purchased three Baofeng UV-5R radios a few months ago. One of them is marked a UV-5R+. I have programmed several of these radios in the past, using Chirp, however for some reason, these three will not allow me to program them. I have tried new programming cables, made sure my Chirp is the latest version. When I plug the programming cable into the radio, it will act as if it is transmitting, which I've had happen before, but with these three, it will show that it is cloning, but will not progress. It will lock up my COM port, and requires a reboot of my laptop. I can check the Firmware that comes up on the radio as BFB297 (on the two UV-5R, I am not able to get the firmware version off the 5R+, not sure if its a different key hold sequence.
Anyone have any ideas how to correct this??
Thank you in advance for any help anyone can provide.
  #2
Old 11-23-2014, 05:44 PM
jwilkers jwilkers is offline
Moderator
Default Re: Troubles Programming Baofeng UV-5R
Make sure you have the proper drivers. It is also essential to use the same usb port, as windows will try to install the latest drivers, which will not work on most programming cables, due to these cables having counterfeit chipsets. You likely need to downgrade your drivers to a pre-crippling version. Many people are going over to FTDI based cables to avoid all the Prolific drama
www.miklor.com is the best source of online info for these radios.
__________________
Licensed ham: KD8DVR
Licensed GMRS:WQWK521
Disclaimer: All posts are personal opinion only and may not state fact or accusation.
Reply
Bookmarks
Tags
baofeng, programming, uv-5r, uv-5r+
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
